I have a 1966 122 Amazon on which I recently completed a major rehab (fuel and brakes lines, brakes, body, interior, gas tank, clutch, front end, full motor rebuild, starter, generator, carbs, etc). I replaced the pinion seal in the rear end but was getting a small amount of leaking so I replaced it again and I'm still getting a small bit of leaking. I checked to make sure I was not seeing leakage from the gasket on the rear end cover and it appears that the leak is definitely coming from the pinion seal. Questions: is it possible/likely that there is some sort of gouge or ding in the race where the pinion seal sits that is allowing oil to leak ? I didn't detect anything significant when I installed the new seal but who knows. If so, how would I correct that issue? Someone suggested I apply silicone sealer to the race and then insert a new pinion seal. Does that sound like it might work? Any other suggestions? It kind of sucks that I rehabed the whole car and I have to put a piece of cardboard under the rear end to absorb the small mountain of oil that leaks from the pinion. Thanks for your suggestions.
The surface where the pinion seal rides can wear a groove over time. This will not allow the seal to seal effectively. You indicate you didn’t see anything but there may be one there.
Refill-sleeves are available to remedy this, would be a combination of a redisleeve and seal to match.
I haven’t checked to see if one is available for your car.
https://www.timken.com/products/timken-mechanical-power-transmission-products/seals/redi-sleeves/
Edit:
Found one, you’ll have to do your own diligence to make sure this is the right one.
https://www.carid.com/national/differential-pinion-repair-sleeve-rear-outer-mpn-99155.html
Thanks, I'll check it out. I presume its just a matter of prying the old sleeve out and taping the new on in. Correct?
John
John
Craig, I think I misunderstood. Are you saying I would install the new sleeve into the existing race and then install a new seal that is specific to the new sleeve? I see now that this would have to be the way to do it since there is no sleeve in the pinion now. How do I get a good seal between the existing race and the sleeve?
The sleeve you linked looks like the one I need. When I order the sleeve, I will ask the supplier for a seal that fits that sleeve, correct?
Thanks for your help.
John
John
I just watched a video of a sleeve being installed. Now I get it. I'll have to remove the pinion seal and get a measurement of before I order the sleeve. Thanks
Edit:
I removed the pinion and seal. The shaft looks fine, no grooves, no pitting etc. Any other ideas on what might be causing the oil leak/
Thanks
slow leak still there
Thanks
I went ahead and purchased and installed a sleeve and new seal. I am still getting a slow (about 1 drop every 1 minute leak from the front of the rear end unit. I checked the race where the outside of the seal fits into the rear end and I did not detect any dents, groves or deformities. The pinion shaft coming from the rear end that the drive shaft flange attaches too has a bit of play (approximately 1/8 inch of movement up and down or side to side. Would this possibly cause the oil leak?
Thanks
