1 - 19 of 19 Posts
I have a 2004 S60 R with 68,000 miles. It recently started leaking fluid and a Volvo dealer says it's the clutch slave cylinder which requires pulling the transmission and will cost $ 1700.
Has anyone had this problem, and does the fix and cost sound right???
Dave Semeraro
Re: Leaking Clutch slave cylinder (David B. Semeraro)
Welcome to SS. Unfortunately, this problem has occurred in many thread discussions and does require the transmission to be pulled to get to the slave. The leaking fluid most likely contaminated what's left of the clutch as well so this should replaced while they're in there. Is this included in the $1700 estimate?
I assume the 1700 includes a new clutch?
You must put a clutch in as it's now contaminated with fluid
With 68k miles of easy driving, its still a good and reasonable idea to put in a clutch.
Its only a few hundred bucks, and while you have all that crap out of the way.
Re: (chinaonnitrous1)
The clutch doesn't always get contaminated but with the mileage you have it may be a safe thing to do while in there.
Re: (Blurry)
Quote, originally posted by Blurry »
Expecially since you're already paying for the labor.
Re: (MagoonR)
I would go a step further and recommend that anyone who's pulling the transmission to do the clutch (or anything else) should do the slave cylinder too. The additional cost is negligible and could save you from spending the $1700 again in the near future.
Re: (bri2k1)
Quote, originally posted by bri2k1 »
Yes you are very correct and this is http://********************/smile/emthup.gif http://********************/smile/emthup.gif advice.
I like when people are smart like you http://********************/smile/emthup.gif
Discussion Starter · #14 ·
Re: (Helmut Ranff)
I took my R to an independent repair shop to get the slave cylinder and clutch changed and they gave up on the repair cause they couldn't separate the transmission from the engine. They were concerned that prying on it would break the case. What's up, any ideas? I wondered if the front transmission shaft is stuck on the clutch disk.
Dave Semeraro
2005 V70R, Midnight Blue, M66
Re: (David B. Semeraro)
If your clutch was working, than the disc is not stuck on the input shaft. Pilot bearing could be snug, but pulling out straight will get it.
Are they sure they have removed all the bell housing bolts?
Just had mine done under extended warranty at an indie. Payed for the clutch on top as well as replacing the rear main seal and the seals on the tranny since I was told its the tranny seal going bad that causes them to fail. I have a six speed, not sure about the autos. the labor on pulling the trans would have cost about 900.
Toby
Re: (63split)
While a leaking rear main seal, or transmission front seal would indeed contaminate the clutch, I do not recall one reported incident of this.
The common failure mode is for the slave cylinder to leak, and contaminate the disc. I hope this was replaced at the time they did the work. Certainly would not hurt to replace the above mentioned seals while in there.
Re: (rogersampson)
Quote, originally posted by rogersampson »
http://********************/smile/emthup.gif http://********************/smile/emthup.gif The cost of the RMS is next to nothing compared to the labor required to change it.
It just makes sense to do it when you have already paid for the labor to replace the clutch
This is sort of like changing out your water pump when replacing the timing belt IMHO.
1 - 19 of 19 Posts
