1 - 20 of 66 Posts
Administrator
Well, I dropped off the T5 to check out a few things and sure enough there were a few things.<p>Appears as though 3 motor mounts are failing. This pict shows the hydraulic front mount took a dump, must have been with in the past 2000 miles, as I was under the car changing the oil and everything looked good, now its stained.<p><IMG SRC="http://gallery.me.com/chris_stewart/100226/DSC00542/web.jpg?ver=12471800870001" BORDER="0"><p>Dealer said the RMS could be leaking. Jim had it replaced, so I dropped off the Keystone receipt so that will be a warranty repair, *IF* the RMS is actually leaking. Its not a return line, possibly the oil pan gasket; its not coming from down on the back of the block. <p><IMG SRC="http://gallery.me.com/chris_stewart/100226/DSC00544/web.jpg?ver=12471800920001" BORDER="0"><br><IMG SRC="http://gallery.me.com/chris_stewart/100226/DSC00543/web.jpg?ver=12471800980001" BORDER="0"><p>So - if the RMS seal is replaced - I may replace the clutch with an upgrade. The current clutch is fine but if I'm in there I'd like to get it fresh. What is the improved setup? S60R pressure plate and S60R disc? any other items needed to swap to that clutch setup? any downsides to that setup?<p><br>
Single Mass wheel <br>850R clutch <p>You cant use dual mas wheel and S60R clutch due tot he splines are different from from your tranny to that. <p>Or get a 6 puck from CJ lol but I woudl want to drive that Daily ...... might die of whiplash
Completely agree with Justin.<p>Maybe a T5-R clutch kit is fine too but you might as well get the R one.
Considering the R and the T5 clutch are the same price I woudl just get the R one incase you decided with a turbo or any other type of upgrade
Administrator
Re: (Chilled Man)
Single mass wheel - Volvo 850R also or is that aftermarket?<p>I am planning to go with an 18t to replace my dying hair dryer.<br>
Re: ([email protected])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>[email protected]</b> »</i></TD></TR><TR><TD CLASS="quote">Single mass wheel - Volvo 850R also or is that aftermarket?<p>I am planning to go with an 18t to replace my dying hair dryer.<br></TD></TR></TABLE><p>Then go with a Single Mass wheel , call erie or vandal for one. <br>and the 850R clutch is the stock clutch for the manual 850R in Europe <p>Its the only Manual R clutch that DWHV sells <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0"> <p>All clutchs from them Gen 1 and P2 are about $175 ish + shipping
Any recommendations/thoughts on after-market clutches? I think mine only has a few months left on it and only found one or two aftermarket ones. Both from shops in europe (rica.nl and schweden-tuning.com).
Re: (Techanic)
The stock clutch is fine
Re: (Techanic)
Now you can delete this too, go to<B> Edit</B>, (far right) then hit <B>Delete</B>
Administrator
Re: (JRL)
She's coming apart next week. <p>All I wanted was some of the sticky C70 grease on my dry steering stops and the coolant system flushed. Now I'm getting a RMS and a new clutch.
Administrator
Re: (Chilled Man)
Anyone have the P/N for the 850R clutch?<p>
Call DWHV the will get you the right one
From my C70 tranny swap thread:<p><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>me</b> »</i></TD></TR><TR><TD CLASS="quote"><br>850R clutch & pressure plate kit 272218 $183.17<br>Clutch 9176268 (Included in above kit)<br>PP 9176262 (included in above kit)<br>850R single mass flywheel 9454774 $236.46<br>Clutch master cylinder 9181217 $142.17<br>Clutch slave cylinder (internal) 8667661 $98.61<br>Rear main seal 9458178 $17.47<br>Axle seals 6843481 $11.50<br>Flywheel bolts (10) 9454743 $14.70<br>Clutch pedal rubber 3546020 $7.74<br>Brake pedal rubber 3546021 $7.74<br></TD></TR></TABLE>
I also forget if your is external or Internal if you going to do all that work might as well go external slave. <p>I woudl of on the XC-M but the spot for the slave where its held onto the tranny was broke off <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/frown.gif" BORDER="0">
Administrator
Discussion Starter · #16 ·
Re: (LloydDobler)
Thanks for the list - going to confirm pricing on Monday. <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <p>
You might want to throw in a new release bearing while you're in there.
Administrator
Discussion Starter · #18 ·
Re: Latest Repairs... clutch recommendation ? ([email protected])
What is the difference between the single vs dual mass flywheels?<p>Does it control how the clutch engages? smoother, harsher?<p>Can the 850R clutch kit be used with a stock T5 flywheel without issue?<p>
I really don't think you can change to a different flywheel than what came with it without some difficulty.<br>A dual mass is heavier so less throttle response, but usually much easier and smmother to engage a clutch
Re: Latest Repairs... clutch recommendation ? (JRL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JRL</b> »</i></TD></TR><TR><TD CLASS="quote">I really don't think you can change to a different flywheel than what came with it without some difficulty.<br>A dual mass is heavier so less throttle response, but usually much easier and smmother to engage a clutch</TD></TR></TABLE><p>I did it, it's a direct bolt on with no difficulty of any kind, aside from the R&R of the tranny... <p>I bought the single mass for the following pros:<p>Cheaper<br>Able to be re-surfaced<br>Handles more power (or so the internet says)<br>Doesn't require special tools to install<p>I've heard the only con is that it isn't as smooth.
1 - 20 of 66 Posts
