Hi!
Running of out of threads to pull here with this car at the moment. 06 s60 2.5t with about 124,000 on it.
Had the car about two years. In that time HVAC has been a bit troublesome. It always seems to work better on recirculate then vent, dramatically so. The first summer on occasion I would hear what sounded like a damper free itself and then the AC would be nice and cold again. It only did this on occasion. This winter I replaced (with a junkyard part) the recirculation damper and did a full re identify and calibrate. Kind of the same.
I then did a heater core thinking well, maybe I don't have enough heating capacity, again here recirc worked fearsomely hot out of all the vents but was weak as hell with it on vent.
So the blower motor does work, but even when on full it sounds like there's just rushing air around everywhere and when I target even just the middle zone it's not were near as strong as my xc70. I poked the camera into the blower motor area and didn't immediately see anything funky. I even popped the cowl up a bit on the outside of the car and the intake passage seems clear enough. When full fan is requested on the dial it reads 90% in VIDA.
There's a bit of mis-fitment in the center console area where it doesn't quite touch the dash itself below the CCM and radio, not sure if that would really be related though.
As shown in the pictures there was some gunk in there. Did a coolant exchange when I changed it out and put the correct stuff in there. I can tell the radiator was replaced about 2016 2017.
