What grade gas do you use?
Does it also knock when you're torquing the engine, like on an incline without shifting down?
quote:
Originally posted by csbrianp:
I resently purchased a 98 S90 that knocks when starting. The knocking appears while the key is being turned. Once the car starts it's fine. Sometimes the knocking is followed by a ticking noise once the car is started (probably a lifter). This car has 92000 miles on it.
Does anyone know what could be causing this?
I use 91 Octane, no there is no knocking under any other circumstances.
Also, I am looking for a operation manual.
I use 91 Octane, no there is no knocking under any other circumstances.quote:
Thank you for the reply. Do you have any idea how to get the headlight washers to work? and, what the three buttons next to the shift lever are for? They read W S E.quote:
Originally posted by InDy:
I think that my 95' 960 makes that ticking noise as well, but I guess I usually don't notice it because I can't hear it when inside the car. I am not sure what it is, but when I had my car in for service a while back, the Volvo folks didn't say anything about it.
-Drew
When you pull back on your windshield wiper stalk to spray and clean the windshield, the headlight wipers wipe and clean as well at the same time. There is no way to do them separately.quote:
Check post below:quote:
...and, what the three buttons next to the shift lever are for? They read W S E.
Brian
