I just picked up 1999 V70R in Chicago.
Red 1999 V70R, 212k miles.
Carfax shows that car was originally sold in IL and no service history until 06/2010 and 124K. After that was serviced by Howard Orloff Imports, Inc. in Chicago until 08/2013, 147K and was sold to 2nd owner. There is a gap until 06/2016 150K some service was done and next on 11/2019 and 212K by 3rd owner, I assume to reprogram ETM.
The good: New ETM from XeMODeX (previous owner bought it from IPD 10/2019 and had a dealer reprogram it), interior is on decent shape no rips, no rust and tires and rims are OK, looks like it has a new Volvo battery.
Not so bad, I guess:
Paint looks good but some parts were repainted like rear bumper (paint is peeling off in couple areas) and perhaps rear door
The bad: Not sure yet as car starts and dies (rough idle), but runs fine above 2500 RPM,
I could not test drive it so no idea on suspension and AWD no spare tire, TB was done at 120K in 2009, also I see a very small leak under the engine and I suspect it could rear main seal. Maybe not.
Third owner (bought it in 09/2019 and never transferred the title) so I’m the fourth owner.
Plans:
Stage “0”
PCV
Timing and Serpentine Belts
Water pump
and on and on….
Work completed:
-PCV
-Serpentine Belt
-Parking brake shoes and cables
-Power-steering reservoir newer version upgrade
-Coolant reservoir
-Coolant Temp. Sensor
-Spark plugs
-Vacuum lines
-Oil change with new magnetic plug
-New air and oil filter
-Cabin filter
-Thermostat
-Engine coolant temp sensor
-OEM fuel pump
Looking to get some advice with this project. I’ve owned few Volvos in the past and my DD is 2016 XC60, so not new to Volvo’s and not afraid to tackle a project at my own garage.
Plans:
Stage “0”
PCV
Water pump
and on and on….
Work completed:
-PCV
-Serpentine Belt
-Coolant reservoir
-Spark plugs
-Vacuum lines
-Cabin filter
-Thermostat
-OEM fuel pump
