· Registered
Replaced a LCD mirror assembly in my 01 V70 a while back and the keyless entry stopped working.
Dealer said i needed a "new" mirror b/c they were progammed from factory.
Can a dealer reflash my mirror to work again with my keyless entry? Or is this gonna cost me a new mirror?
TIA.
· Registered
Re: Keyless woes (BenW)
did you replace the interior rear view mirror?? if so it needs to be downloaded to work properly and yes it will affect your keyless entry because it is the antenna for your remotes. if it is programmed all should be ok after that.
just saw your post on VS.... the modules can only be programmed to one car usually so since you got a used one i think the dealer is correct to say you need a new one to repair it now.
Modified by ovlovtech at 10:54 PM 4-24-2006
