There is a VIN break for switch #1 and #2. #1 switch pulls the key in, #2 switch does not.
Switch #1 needs SCU software. SCU = Start Control Unit. I assume that you have non-keyless ignition.
Non-keyless, press the remote to lock/unlock doors, insert the key to start the car.
Keyless, pull outside door handle, door unlocks. Do not insert key, press button, engine starts.
You can do a Swedespeed search for ignition switch and look for post for your car to see if there is a fix.
The gear teeth get worn that pulls in the key in/out. You may be able to use pieces to make you switch work again.
