This guide is useless for your car.
Don't spend your money to used fobs. You cannot tie them with your car without codes.
The cheapest way I think to find a set (from the same car) of fob+mirror from the same MY car as yours.
I've never heard of this: "The Volvo keyless entry remote control must be reprogrammed if its batteries go dead."
It MAY be true of some model years, but I don't know which.
For the 2002, VIDA says:
36: Automatic monitoring
Ignition key/Remote control, adding/replacing/erasing
Note! The illustrations in this service information are used for different model years and/or models. Some variation may occur. However, the essential information in the illustrations is always correct.
Caution! When replacing an ignition key or remote control, the new unit must be programmed. Both software and the code on the packaging are required to add a new remote control. Only the software is required to erase a remote control. Only software is required to add an ignition key.
Ignition key programming/erasing
Order the software. See 9438428
Remote control programming/erasing
Order the software. See 9438429
Finishing
Check the function after programming an ignition key or remote control.
