Which model and year? My V50 powers the cargo plug full-time, but the cabin ones are switched, powering off after a delay.
Just wire the front plug to the cargo plug power. I did this and it works fine.
Unfortunatly it is not an easy job. You need to remove some panels and lift some rugs to find the wires and run a wire from the back to front.
I added my own socket in the trunk when I wired in some radios back there. There should be an always-on fuse you could tap up front.
