Lol, I wish!d'oh.... at lest that is a easy fix.
Really you couldn't unhook it on one end and then fish a line through the car and pull in the new flex pipe or attach a new pipe on one end and use a dual headed male extender (like the one they sell for water heaters) and pull the new pipe into place? At least that is what I would try to do.Lol, I wish!
That hose runs from the oil cooler behind the grill, through the bumper, down under the engine, and wraps around to the steering rack. I've been told I have to lower the front subframe to replace it!!
If only it was a flexible line the entire length. It is only flex for the part that runs through the front bumper. Once it gets down by the pulley, it is pressed into a hard line that runs under the engine and across. I would imagine that is why it is difficult. Planning on giving it a go myself, just haven't had the time to mess with it. So many other priorities right now!Really you couldn't unhook it on one end and then fish a line through the car and pull in the new flex pipe or attach a new pipe on one end and use a dual headed male extender (like the one they sell for water heaters) and pull the new pipe into place? At least that is what I would try to do.
Welcome to the group.Hey all, just found this thread - nice to see some people located in my part of the world. I'm over in Topeka.
Definitely!Hi Turbine! We used to have some group car days. If we get those going again, you should make the trek over!
Drilled a bit smaller hole with a hole saw, and finished with a dremel and sanding disk. Took about 3 hours to get it perfect! Almost $400 lower valence so I had ONE chance.Wow! I'm impressed. How did you do it?
I can start hosting some car days later in the year. Put in some bids on a few houses. Hopefully we'll be out of this place by end of Spring!
Good luck.Wow! I'm impressed. How did you do it?
Hey Ish. I have vida and can read your car if you need. Anytime after ~5p, just give me a call. PM if you need my number!Anyone know a good cheep machinc? I have a check engine light and being unemployed I don't want to pay a lot. Plus I think I have a oil leak.
