KANEX AIRBLUE
a portable Bluetooth music receiver that operates on battery
The above listing is for a BARELY USED Kanex AirBlue portable Bluetooth music receiver that perfectly works for iPhone's, iPods, iPads and some Android phones if it has Bluetooth capability. I love this little device because it is ultra light to carry around and the sound quality is very good. Streaming is easy and covers a good range. Works perfect in your car. I used it in my 02 S60 with premium sound system. Never had any problems. When I'm not in my car, I use it with my headphones or my sound system at home or work. Of course you will hear humming noise when the receiver is too far from the device or is blocked by seamlessly bigger particle.
Description from Kanex:
The Kanex AirBlue™ is a portable Bluetooth-based music receiver that simply enables you to wirelessly play, listen and control all your favorite media from your iPod touch, iPhone or MP3 player through your home stereo/speakers or in your car sound system.
Convenient and portable
Enjoy the convenience of portability by taking the AirBlue anywhere you go. Stream directly to an existing stereo, a friend’s home entertainment center, or even in the car.
Simply connect the receiver to your home stereo system with the included cables, and then pair your device to the AirBlue. Stream wirelessly to listen to, share, and control your music from up to 33 feet away. The AirBlue receiver uses Bluetooth v2.1 with EDR to provide you with high fidelity and premium sound.
Control Bluetooth devices over AV
Share, control and listen to your favorite playlist or podcasts wirelessly using the Kanex AirBlue through your home-theater AV receiver or powered speakers using the included audio cable.
Charge via USB / Long-life battery
In case you're running out of juice, no cumbersome power supply is needed to charge the unit. Simply connect it to a USB powered device and start streaming your favorites over the air. With up to 10 working hours, you'll have more than enough battery to keep your tunes playing all day long, no matter where you are.
Bluetooth Version: v2.1 with EDR system in 2.4GHz ISM band
Transmission Distance: 33ft.
Device Compatibility: Devices enabled with A2DP stereo Bluetooth
Included Cable Types:
1) 3.5mm to RCA
2) 3.5mm to 3.5mm
3) Mini USB to USB
Terminals: Combined TX/RX RF
Processor: DSP Co-Processor - 16 & 32-bit run time
Output dB: +4dBm with level control 13 dB
Audio Codec: 16-bit stereo codec - 94dB SNR stereo DAC playback
Battery: Internal rechargeable battery
Working Hours: Up to 10 Hours
