K&N filter issue
1192 Views 10 Replies 6 Participants Last post by  Jersey R
was cleaning the debris from my K&N filter yesterday (gives you a good HP gain)...
for those of you familiar with the K&N..
the K&N attaches to the intake with a small section of a large diameter hose and 2 hose clamps...
anyway.. the tightening of the hose clamp on the filter side cracked the filter in the corner around the collar... i wrapped the collar in hockey tape to seal it up...
i suspect air and debris were bypassing the filter thru this crack (there was separation in the crack)
i also suspect this could be common with others using the K&N filter...
Modified by Jersey R at 9:40 AM 3-11-2009
1 - 11 of 11 Posts
I had this happen as well. Some of the K&N filters have the wrong size opening. K&N replaced mine for free. I wrote them a detailed letter including measurements. Here is the part that gives you the dimensions
The new K&N is in (on left) and the hose fits it like a glove (I switched hoses and both hoses are identical in measure). The new filter is 2 mm larger everywhere (opening OD/ID and both end diameters of the filter) Opening has 85 mm OD compare to the original (on right) having a 83 mm OD. (New filter (left)has 75 mm ID at opening versus 73 mm on the original)
Re: (JDS60R)
Definitely a common problem.
Good old K&N.
Re: (Needsdecaf)
Send them an email. Mine came without the hose piece. The price buys you a lot of customer service
Re: (JDS60R)
Thanks.. i sent them an email yesterday.. it can't hurt to ask....
2
Re: (Jersey R)
K&N customer service rocks...
i sent them an email..
they asked for a mold # from the filter, and where & when purcahsed... new filter is in the mail.....
wow new replacment filter.. much better than the hockey tape.... http://********************/smile/emthup.gif http://********************/smile/emthup.gif
just don't see that much anymore......
Re: (Jersey R)
told you. http://********************/smile/emthup.gif
Re: (Jersey R)
Follow up....
i got the new filter...
the diameter on the small piece of hose they provide was a much better fit compared to the original... snug fit vs. 1/2" too big...
2
Re: (Jersey R)
Quote, originally posted by Jersey R »
Where did you get the Mold#? I didn't see it.
Re: (Jersey R)
Mine was replaced for the same problem w/ no issues on their end, except they sent me the wrong model; same digits but mixed up. Once I returned that, I ended up w/ two new units. Schweet. Great service. http://********************/smile/emthup.gif
Go easy on tightening the clamps. Scott
Re: (badams1897)
Quote, originally posted by badams1897 »
it was raised lettering on the black rubber on the "non-open" end...
There are also raised numbers around the collar on the open end... (i noticed this on the new filter, but the old filter i had taped up the crack, so i couldn't see the collar area...
1 - 11 of 11 Posts
