1 - 11 of 11 Posts
Just ordered new shocks and struts, question about SUM
Talk about a kick to the pants. New shocks and struts $1141. Ouch. Well that hopefully should cure the bouncing down the road and bottoming out problem.
Where did you purchase them from? I'm pretty sure Rock auto has some great prices for them.
So from what I've been reading is after I install the new shocks/struts I need to do a SUM calibration. Is this correct? So I guess I need to order a Dice/Vida unit?
You can but the dealer should do it for 30 ish dollars.
Oh that's all? I thought I read some where the dealer charged like $300 to do that. Sweet thanks!!
Did you order new spring seats and support plates for the front. I'd say 1) get it done now instead of having to go back in later and 2) go OEM. I went with aftermarket spring seats and the first set wore out in less than two months, the second set has lasted about 6 and needs to be replaced.
I have one of the ipd hd spring seats but also one of the Sachs aftermarket brand that ipd offers. neither has shown any substantial wear. may not want to go with one of the really cheap brands though especially if you don't do your own labor
Sent from my Blackberry Playbook
I was going to do the labor myself so I'll check out the seats and support plate. Also just talked to the local Volvo dealer and they said they wouldn't charge for the SUM calibration so that's pretty sweet!
Discussion Starter · #11 · (Edited)
For the spring seats and support plate do you have a part number? Also where is a good place to buy the spring seats and support plates from?
Edit: Never mind I found the parts on tasca.
1 - 11 of 11 Posts
