1 - 8 of 8 Posts
Only 5 items (in bold) are replaced and the LONG list of checks. They sure know how to make 'a list'. All this for a whopping grand after tax!!! I did the bold items plus a plethora of others myself two weeks ago and it costs me about $160 in (genuine) parts.
What does your S40 need?
MAINTENANCE PACKAGE: 75K Service
Factory Maintenance Services*
$904.44
Cabin air filter, replace
Engine oil and filter, replace
Up to 6qts of Oil
Engine air cleaner (ACL), clean the air cleaner housing / replace filter
Spark plugs/ replace
Time-based Reminder - Vehicles with temporary tire sealing kit, check an…
Brake fluid, replace
Battery (check charge and electrolyte level)
Battery, check fluid level and mounting
Brake pads/discs, check and adjust fluid levels
Check and adjust brake fluid, clutch fluid, power steering fluid, washer fluid, coolant
Driveshaft joints, check for wear/play
Driveshafts, check boots
Engine coolant, check and adjust antifreeze rating/anti-corrosion agent
Engine, check for leaks
Check for signs of oil, coolant, power steering and brake fluid leaks.
Engine/Transmission/Timing, gear, check for leaks
Exhaust system/ check for damage leaks
Headlamp wiper washer, check/adjust
Parking brake, check/adjust
Rear suspension, check for wear
Service Reminder Indicator (SRI) reset
Steering/front suspension, check
Tires, check pressure, wear and condition
Top up engine oil
Windshield wiper/washer, check/adjust
I have noticed that at my local dealership as well. Oil change and air filter change is 400$, with a overall check that would be standard or complementary at my local Chevy dealer.
All of that is basically just checking stuff too! Imagine if they had to do something do it.
I've said it many times on here and I'll say it again: if you are not doing the work yourself and you need a service, just pay for the items that are replaced a la carte. You'll almost always come out cheaper. Any tech who wants to make money will check over the car no matter what it's in for.
Changing the cabin air filter is almost worth the price (almost).
I've said it many times on here and I'll say it again: if you are not doing the work yourself and you need a service, just pa6 for the items that are replaced a la carte.
I'd say, if you are not doing the work yourself, get a Toyota before you go bankrupt... lol
1 - 8 of 8 Posts
