A little update after using the BC for some time now.
So far I am 90% happy with the BC.
I settled to two settings. cruise and power
One is at ~13 psi and on at 19 psi with the safety mode set to reduce boost a litte when 20 psi is reached, it happens sometimes with rainy weather.
Every now and then I readjust the gain setting because the gain is sensitive to type of weather.
We had high humidity and temps over the last couple of weeks, mostly between 25 and 30 degree C.
The problems I'm still running in to are an overboost warning and sometimes an ECU power reduction to 2000 rpm without boost, with the power reduction it seems like the ECU is keeping the turbo from doing it's job because 2000 rpm is below the spooling point of the turbo.
I had the reduced power problem twice so far but never at full throttle but in the mid throttle area.
One DTC gave me 70% calculated engine load at 4200 rpm and this is an area where I am not so happy with the BC.
When driving through higher speed corners I never lift the throttle completely but I reduce throttle up to a point where I think the engine gives continious power.
I sort of lever the throttle between this point and almost full to build more power if possible and keep the nose of the car in front, keep it balanced, but this is where the BC starts working against me.
It somehow doesn't respond fast enough and sometimes it allowes a high boost peak.
When the ECU want's to cut the boost peak it discovers it can't because the BC is a standalone and then it just cuts all the power for safety reasons.
I want to check the wastegate lever because I have a suspision that it has a "tight" point in it's stroke, like the actuator has to overcome an amount of force before it can move on making it "overev
" on the stroke.
I received a new chip yesterday with altered boost margins but I didn't install it yet.
PS forgive my sometimes bad explanaitions of things.
