Think he might be referring to the physical garage spotHmm. Ceramic coatings?
Yes, that is the upgradeOhh! Like a new house with a garage?
No ceramic coatings for this car!!
She is just glad (as am I) that there will be enough space for there not to be Volvo parts in the house anymore. Once I make the attic functional, everything, with the possible exception of the wheel collection, will be contained to the footprint of the garage.Good for you!!
Just make sure you leave space for your mom.![]()
Nice, the P80 market just keeps on 📈This issue just dropped, thought you might find it of interest for some reason 😆
Great magazine, btw….I have never seen a print copy, but I discovered it with some other digital issues I get. The Brits always do the best ones.
Haven't done it in either of my 850s. The hypothesis says that should be a problem with the DW300 in my R but my AFRs are rock solid under load. Now that you mention it I remember hearing about it somewhere but I completely forgot after not having any issues on the stock harness.Have you upgraded (increased wire size )the wire to the pump to avoid voltage drop under load? I still need to do mine, but it's supposed to be a must do.
Aaron at VAST is the one that told me I needed to do it because my fuel was dropping off under high load. I'm running the DW200. I haven't done it yet, but hope to soon so Aaron can finish my tune.Haven't done it in either of my 850s. The hypothesis says that should be a problem with the DW300 in my R but my AFRs are rock solid under load. Now that you mention it I remember hearing about it somewhere but I completely forgot after not having any issues on the stock harness.
Some of this stuff I have to wonder if it's actually an issue or if a legend was born out of someone's super broken car.
It actually uses all three plastic, rubber and metal.Does the stock 850 pump assembly use rubber fuel line? I can't remember, I always prefer to use the plastic hard line with oteiker clamps a la P2
I doubt kinking would be an issue with the design of the 850 sender, but definitely is a problem on P2
Everything you see in the picture is factory Volvo except the pump and the oetiker clamp. The line from the pump to the top of the insert is rubber.Does the stock 850 pump assembly use rubber fuel line? I can't remember, I always prefer to use the plastic hard line with oteiker clamps a la P2
Interesting; I have received no such feedback from him about my R, but I'm also running a DW300 in that car because I was concerned the DW200 may not be adequate. Aaron actually recommended a DW200 for that car as he was concerned the DW300 would overload the stock pressure regulator, but that doesn't seem to be an issue for me or the other P80s that I've heard of DW300s being installed in.Aaron at VAST is the one that told me I needed to do it because my fuel was dropping off under high load. I'm running the DW200. I haven't done it yet, but hope to soon so Aaron can finish my tune.
You inspired me to do the same with a walbro and housing I had laying around. Where is the check valve (that keeps pressure to the rail) on these set ups ? Is it built into the pump ? Not seeing any external valve on my 99 and 00 P80's.Fuel pump relay potentially exhibiting signs of wear so I dropped a DW200 into an extra fuel pump carrier. I just put in a fresh tank of gas so I'll plan to replace the pump at the end of this tank, but wanted to have a fresh pump on board so I can fix it in the field in case of emergency. I already carry 2 spare relays with me.
Love how easy this install is
Don't even need any of the DW install kit.
