1 - 20 of 26 Posts
Re: It rusts like an Alfa... (Johann)
Volvos don't rust...
(above is after just 8 months)
You must have never owned an alfa. Mine disappeared after several years, replaced by an orange fluffy pile on the floor of the garage. Taught me everything I did not want to know about bondo!
regards,
Rich
Banned
Re: It rusts like an Alfa... ("R" Kelly)
Quote, originally posted by "R" Kelly »
I will mention it when I pickup the parts for my 60K(km) service nxt week or the week after (or after that)....my endpipe is also showing some spots
..I think I can make them want mine to change
hahahahaha sissies
EDIT:
And to Johann:
that's no rust
that's just paint pealing off
(but that part will never rust coz paint has gone!)...the reason why I NEVER use a high-pressure waterspray on my paintwork when washing the car..1 stone-marking is enough to get the high pressure-water under it and the paint blows away
Modified by JARMO at 7:59 PM 5-12-2006
Ha, ha! Just had to read this as a former Alfa owner. On my Alfa, the frame rails rusted and the frame collapsed to the point that it was tough to open the doors.
I saw your other post that described the IC coating- I have some large flakes too, but not on the horizontal bars, just on the vertical part.
Can you repaint this with just a can of flat black spray?
Re: It rusts like an Alfa... (flyfishing3)
Quote, originally posted by flyfishing3 »
mines about the same, you can kind of see it in this pic. i asked about volvo covering it also and was laughed at.
I don;t see anything but there IS a rust and corrosion warranty which should cover anything on the body unless it is caused by open metal (ie: paint chips or accident)
Discussion Starter · #13 ·
IC has been replaced under warranty..
Also driveshafts glued and front rotors turned.
Ready to go again! http://********************/smile/emthup.gif
Re: It rusts like an Alfa... (pino)
I wonder if it might be possible to bolt sacrificial anodes on rust-susceptible portions of the car. These are metallic substances designed to rust so the rest of your (ship/submarine/tank/...S60R) does not. I think they were typically Zinc based.
Re: It rusts like an Alfa... (vLGrok)
I don't see any rust in those photos of the front ends. I see some paint that has flaked off what appears to be galvanized parts, probably due to rocks hitting them. Now the exhaust photos, that's rust. oclv
Administrator
Quote, originally posted by Johann »
Looks like it's NOT covered under warranty.
Wow, I would think that the paint warranty would cover that - it should not be pealing off like that. -- What do you think caused it to start coming off? Salt on the roads during the winter?
Re: It rusts like an Alfa... (oclv)
Mine has done the same thing as well ... at the April GTG I showed a few people that it was happening to most of the cars there. I know Kelly had some peeling and KVB has bubbling on his. I was washing my car, by hand, one day and the small front intercooler fins started peeling on me. I noticed that it had bubbles towards the outside where it didn't fall off yet. I took my car in for warrenty work and for them to look at this. They told me that they sent pictures to Volvo for eval. I can see this being a bad problem for ALL R owners! Maybe they'll come out with a proper FMIC now.
If you look close enough you can see mines missing some paint too ...
Discussion Starter · #19 ·
Quote, originally posted by oclv »
It's alloy.. I thing you guys prefer to call it corrosion instead of rust..
I know I'm resurrecting an old thread, but I'm experiencing the same issue and am wondering if anybody has successfully gotten warranty coverage for this. If not, any suggestions as to how to fix? I'm thinking of just sanding off all the peeling paint, scuffing the galvanized metal and using some kind of black heat resistant engine paint.
1 - 20 of 26 Posts
