1 - 2 of 2 Posts
Hello everyone, new member here. I have a 2012 S60 T6 R-design. Looking for advice on where to start. I have two issues that started after my engine died and left me stranded in the middle of nowhere. I was told the computer was bad and replaced.
Before the incident I did not have any check engine light.
After I got the car back the check engine light was on and when I checked it was a PO420. Second issue is minor but the clock resets to 12:00 o’clock every time the car is started. I have checked fuses and they are ok.
Could these two issues be related electrically?
Where should I start on the PO420, o2 sensor? Rear or front? Or just replace the cat? Anything I need to know before starting?
For some reason this Volvo intimidates me a bit, I’m wondering if there are any known issues that could steer me in the right direction. Thanks in advance!!
Need some more info here, where did you get the computer replaced at? I am assuming at a Volvo dealer? If so, it seems like the check engine light and issues with the clock occurred almost immediately after you got the vehicle back. I would return to whoever did the repair and bring up these issues. Seems like more than a coincidence that both problems popped up right after having the computer replaced. Put the onus on them to fix the problems before trying to resolve them yourself.
1 - 2 of 2 Posts
