1 - 13 of 13 Posts
1997 850 FWD, 2005 S80 AWD
As it says i need the trans, pedal assembly, clutch flywheel and anything else i need that i maybe forgeting. I have 98 v70 r motor in the 850 not sure if it makes a difference. Ready to buy. I know i can use the cv shafts from auto, but I'll probably end up buying heavy duty ones if possible.
95 850T Wagon
As usual, I'll give five dollars more than whatever this guy offers.
Sent from my moto g(6) using Tapatalk
So I now have a transmission, was curious if anyone had a ecu? Also was curious if anyone by chance has a "like new" or "slightly used" clutch, pressure plate, and single mass flywheel?, that I'd be real interested in getting.
I am searching for a pedal assembly for an 850 bc I'm almost positive the s70 pedals I got will not work, worse case scenario.
I guess the ecu would have to be out of a manual t5. I'm not sure about what years are compatible but I'm assuming the same as trans 94 -2000 models with the t5 and manual. Not a 100% certain
if you can't find a factory ecu you can get a m4.4 manual R tune from VAST
1 - 13 of 13 Posts
