Eastwood makes this rust converter chemical. I have used it for years on cars and tools. It works well.
You just brush it on and the rust turns black. You can than paint it. No sanding or removal of the original finish.
Transforms surface rust into a paintable surface!
www.eastwood.com
Description
We've learned a lot about restoration projects over our decades of experience helping the DIY community fix up their fixer-uppers. While each project is filled with its own unique challenges, we see some common problems between them all.
One of those things is rust.
Vehicles in need of restoration have usually been sitting out in the open without a lot of maintenance, where time can have their way with them. We offer more than 4,000 products to help DIY enthusiasts complete their projects successfully. When it comes to residual rust, we have a perfect solution: Eastwood Rust Converter. This product is a unique rust neutralizer that leaves behind a paintable surface without the need for sanding.
- Rust Converter stops residual rust, and turns it into a black, protective, ready-to-paint coating, without sanding. Just apply to transform the rust.
- Penetrates faster than other brands.
- No mixing needed.
Eastwood's own high-tech formula converts rust into a protective polymeric coating that's ready to go as a primer, and is compatible with most top coats. That new protective coating will also seal the surface against moisture to prevent future rust growth.
Our customers have told us about a lot of different uses for this versatile product. Available in an aerosol spray or liquid containers, this rust converter will help you either restore or maintain your project vehicle. Contact us today by phone or email, and we'll answer your questions about whether this handy product can help your situation.
This high-tech formula halts residual rust in its tracks and converts it into a black protective polymeric coating that eliminates the need for sanding. The converted protective coating is a suitable primer, and is compatible with most top coats. Simply remove loose rust with a wire brush, then apply Eastwood’s Rust Converter. Allow to dry, then top coat it with a quality coating, such as Eastwood’s Chassis Black. Single component; no more mixing.
