1 - 20 of 32 Posts
Re: (zigger)
The shifter should have 3 contact points. Upshift, Neutral and Downshift. You can tap into them and install your own paddles/buttons/whatever on the back of the steering wheel.
Re: (Volvo Grrrr)
There was a BMW club magazine that had a set of paddle shifters made out of CF someone was making and sell, but I haven't seen the ad for a while now.
That would of been a good start.
Maybe someone with back issues could look.
Re: (zigger)
Quote, originally posted by zigger »
I would love that! Is there a paddle Kit that anyone makes? I am surprised nobody has done this yet?
If you look closely, you can use your "Geartronic" to manually shift gears up or down. You have 6 gears to choose from.
Re: ("R" Kelly)
Quote, originally posted by "R" Kelly »
LOL
Re: (zigger)
The GT +/- uses Hall Effect devices... you need to tap into that and mimic that +/- level. Similar Hall Effect devices could be implemented on the steering column.
This is not a learn as you go DIY job though..........
Re: (Our R)
Quote, originally posted by Our R »
There was a BMW club magazine...
I've got a lot of old Roundels (although I've recently started clearing some of them out at my wife's request). Any idea when it was published? I've got a MT but I'd be happy to provide the info if I can find it or have it.
-Eric
Re: (adamrs80)
Quote, originally posted by adamrs80 »
I think it would be difficult to make it look nice and factory, although technically it sounds pretty feasible.
That's why I reccomended buttons. Something that would fit behind the spoke and and be big enough to press when you wanted to shift.
Re: Is there a way To Make or ADD paddle shifts on a GT R (frankhoffy)
Quote, originally posted by frankhoffy »
I want my 4C controls on the steering wheel too
If you have the will, you will find a way
Re: Is there a way To Make or ADD paddle shifts on a GT R (zigger)
I wouldnt try it.
In order to do this you would have to run thru the SWM via the Contact Reel(SRS area) in order to access the GSM. Not highly recommended, by me anyway.
Re: Is there a way To Make or ADD paddle shifts on a GT R (854T5)
Quote, originally posted by 854T5 »
I wouldnt try it.
SOS!
What if you mounted paddles on the steering column so they were fixed?
I like that style anyway - that way you always know where the paddles are, instead of being all crossed up when steering.
I really like this idea....and yes, I know the GT is only a foot away from the wheel.
2019 S60 Pine Gray, M. Brown, Lin. Lime
Re: Is there a way To Make or ADD paddle shifts on a GT R (needsdecaf)
Steering wheel ... How many turns lock-to-lock? ... Have to wrap this wire around there that many times ... Tape it gud so it don' come loose ...
1 - 20 of 32 Posts
