Re: Is there a PCV (Mika)
<br>It would be pre-turbo, that is the only place that isnt pressurized.
Re: Is there a PCV (iontrap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>iontrap</b> »</i></TD></TR><TR><TD CLASS="quote">Is it under the black plastic cover?</TD></TR></TABLE><p>No, it's under the intake manifold. The PCV system is rather much more complicated than in some other cars. Here's how it looks:<p><A HREF="http://www.ipdusa.com/Volvo-XC90/Engine/Engine-Mechanical/PCV-XC90-5-Cyl-Turbo/p-105-596-609-4738/ " TARGET="_blank">http://www.ipdusa.com/Volvo-XC...738/ </A><p> <IMG SRC="http://www.ipdusa.com/uploads/images_products_large/4738.jpg" BORDER="0">
It is, but let's say skill level 3. More difficult than changing plugs but easier than changing the timing belt.<p>I have only done this with an S60; the XC90 has more room to work in. <br>Cleaning the nipple can be done without removing the manifold.<br> <A HREF="http://turbobil.com/SMF/index.php/topic,37.0.html" TARGET="_blank">http://turbobil.com/SMF/index.php/topic,37.0.html</A> <p>Changing hose and the oil separators requires removing the manifold. Also, you need to do that to see if there's excess oil going into the cylinder 1 intake.<p>You can use a simple 'balloon trick' to check the health of the system. The crank case should have negative pressure. Remove the dipstick and put a balloon tightly on the tube. If it starts filling up the PCV is clogged.<br>
