I have searched but to no avail, am planning on changing the pump rear shocks and rear control arms this weekend
by coincidence, just last night, i saw a you tube video about changing pump and fluids. look for changing haldex, etc on you tube and you should come up with something
Yeah there's several good YouTube videos on it. Pretty straightforward.
Depends on which generation Haldex you have. The later versions are easy... If you have to remove the driveshaft and output flange to access the pump life gets interesting. Hint: Use a bent long punch and BFH in the two blank driveflange holes to get the rear CV/Driveshaft out.
To do it over again I'm sure it would be easier, but it was frustrating the first time around. Note this was on a 2006 XC70, but all the Haldex systems are very similar per generation.
Good Luck!
