1 - 17 of 17 Posts
So, I talked to a service advisor at my local dealer and he doesn't know what i'm talking about when I told him I wanted afterblow enabled on my car. Is there a code or something I can give him?<p>Also which vents does it blow out of when it engages? Defroster? Vents? Last position the hvac was in?<p>Thanks.
Re: Is there a code I can give dealer for Afterblow... (firehawk618)
The code is to go to another dealer, <B>yours is an idiot</B><br>That is what it's called, tell him to go and look it up
what's afterblow?
Re: Is there a code I can give dealer for Afterblow... (bcheng4jc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>bcheng4jc</b> »</i></TD></TR><TR><TD CLASS="quote">what's afterblow?</TD></TR></TABLE><p>I guess search is broke <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> <p>The blower turns on to dry out condensation from the A/C that would otherwise leave you with a musty smell in the car.<p>It comes on around 30 minutes after shutting her down and stays on for 40mins (or something like that). If yours doesn't work just follow JRL's advice.<p>LTA<br>
2005 V70R, Midnight Blue, M66
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>firehawk618</b> »</i></TD></TR><TR><TD CLASS="quote">So, I talked to a service advisor at my local dealer and he doesn't know what i'm talking about when I told him I wanted afterblow enabled on my car. Is there a code or something I can give him?<p>Also which vents does it blow out of when it engages? Defroster? Vents? Last position the hvac was in?<p>Thanks.</TD></TR></TABLE><p>TNN87-53-2005-11-21 Title: Air Conditioning, 'Afterblow' Function. <br>Under certain conditions, customers may complain about a musty odor from the A/C system. Activating the afterblow function will minimize this from occurring.<p>Regarding vents, it uses last settings used, with the exception of blower speed, which is forced HIGH.<p>Period after shutdown is 50 minutes, run duration is 7 minutes.
Hmm, maybe that's why my napkin on the defroster vents didn't move. I always have it on dash vents with the a/c running.<p>So if the car is shut off with the a/c on afterblow will go after 50 mins if it is activated.<p>What if the a/c button is shut off just prior to turning the car off? No afterblow that way?
Re: Is there a code I can give dealer for Afterblow... (JRL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JRL</b> »</i></TD></TR><TR><TD CLASS="quote">The code is to go to another dealer, <B>yours is an idiot</B><br>That is what it's called, tell him to go and look it up</TD></TR></TABLE><p>I really LOLed!
Re: (firehawk618)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>firehawk618</b> »</i></TD></TR><TR><TD CLASS="quote"><p>What if the a/c button is shut off just prior to turning the car off? No afterblow that way?</TD></TR></TABLE><p>THAT I cannot answer, but since it's electronic, it shouldn't matter
Re: (firehawk618)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>firehawk618</b> »</i></TD></TR><TR><TD CLASS="quote"><br>What if the a/c button is shut off just prior to turning the car off? No afterblow that way?</TD></TR></TABLE><p>If the AC was run during the Drive Cycle, afterblow should run if enabled.
Re: (firehawk618)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>firehawk618</b> »</i></TD></TR><TR><TD CLASS="quote"><br>What if the a/c button is shut off just prior to turning the car off? No afterblow that way?</TD></TR></TABLE><p>It only considers if there were compressor on/off cycles during driving.<p>You may well have it enabled and it still does not work. Have dealer check his TNN's for this issue. <p>As an aside, I am not sure what is to be gained by shutting off the A/C. Modern rotary compressors use less energy that what is used by driving with your window down, and the increased drag caused by the open window.
Re: (rogersampson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>rogersampson</b> »</i></TD></TR><TR><TD CLASS="quote"><br>As an aside, I am not sure what is to be gained by shutting off the A/C. Modern rotary compressors use less energy that what is used by driving with your window down, and the increased drag caused by the open window. </TD></TR></TABLE><p>That may be true, but it heats up the intercooler, leading to higher IAT and reduced power<p>See Needsdecaf's signature <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
Re: (FEO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>FEO</b> »</i></TD></TR><TR><TD CLASS="quote"><p>That may be true, but it heats up the intercooler, leading to higher IAT and reduced power<p>See Needsdecaf's signature <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> </TD></TR></TABLE><p>It certainly contributes some heat, but I suspect that the calories of heat contributed by it, relative to the calories of heat dissapated by the engine radiator would get lost in the rounding. Even it did allow more power to develop, the extra drag caused by the open window may off set it.
The last report I saw on it was that drag caused by an open window exceeds parasitic drag caused by the compressor above 60 KPH.<p>Basically, window down in town, window up on the highway.
Re: (rogersampson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>rogersampson</b> »</i></TD></TR><TR><TD CLASS="quote"><p>It certainly contributes some heat, but I suspect that the calories of heat contributed by it, relative to the calories of heat dissapated by the engine radiator would get lost in the rounding. Even it did allow more power to develop, the extra drag caused by the open window may off set it.</TD></TR></TABLE><p>The effect is more significant than just the calories in the air. <p>A/C condenser heats intercooler. <br>Hot intercooler, vastly more inneficcient<br>Inefficient intercooler leads to higher IAT<br>higher IAT <i>directly</i> affects max tq generation (Phuz or JimLill may have those numbers, but they are not "round-off" quantities)<p>to see how catastrophic the AC effects are, see here <A HREF="http://forums.swedespeed.com/zerothread?id=39168" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=39168</A><br>from 90->150 deg!!<br>
Re: (FEO)
Thanks for the input, I will review the thread.<br>I don't want to pull this thread off topic any more than I have!
Re: (rogersampson)
+1 apologies for the hijack firehawk, but it seems like you found another dealer that can enable your afterblow right? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0"><p>one last comment <p><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JimLill</b> »</i></TD></TR><TR><TD CLASS="quote"><br>Tech Note #13<br>The discussion often comes back to IAT, the intake air temperature at the manifold.<p>I ran some simulations on an R-based model.....<p>each 1 deg Celsius increase in IAT results in peak HP being 1 HP less just based upon combustion factors alone.<p>If were able to keep the Intercooler at its peak efficiency, each 5 degC rise in ambient results in a 3 degC rise in IAT.<p>When the ECM senses high IAT it may take other protective measures that would further reduce HP.</TD></TR></TABLE><p>from <A HREF="http://forums.swedespeed.com/zerothread?id=94482&page=3" TARGET="_blank">http://forums.swedespeed.com/z...age=3</A><p><br>EDIT <br>to the OP: look here <A HREF="http://forums.swedespeed.com/zerothread?id=105524" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=105524</A><br>there are some afterblow P/N's there, but I think they change year by year (or the info maybe outdated)<p>Like JRL said, another dealer is the best code<br><BR><BR>
<i>Modified by FEO at 9:07 AM 7-16-2009</i>
1 - 17 of 17 Posts
