1 - 6 of 6 Posts
Hi all as per title I have a 2001 x 2.4 v70 which I wanna do the clutch on but not sure if I have dmf some sites say yes some say no coz of engine number? 2209572 so Im confused eurocar parts have 2 listed one engine number from 4294026 and other from 2659498 to 4294025 its an early p2 model with B5244S engine as far as im aware if its dmf is there a conversion kit? thank you in advance
Every manual Volvo after 99 is DMF I believe. No conversion kit, per se, all the parts are interchangeable between 94 and 03. I used a 97 850R clutch and single mass flywheel in my 04 C70 with an 02 transmission. The input shaft spline on the transmisison changed in 03.
Nope, either clutch cylinder/throwout bearing will work with either assembly. You just need all 3 pieces: Flywheel, pressure plate, and clutch plate. No harder than any other clutch/flywheel to install.
1 - 6 of 6 Posts
