1 - 10 of 10 Posts
Re: Is it normal for brakes to squeak a bit (waccamatt)
it is "normal" to an extent. How did you bed them in? At all? Or just drive it....?
Re: Is it normal for brakes to squeak a bit (JimLill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JimLill</b> »</i></TD></TR><TR><TD CLASS="quote">it is "normal" to an extent. How did you bed them in? At all? Or just drive it....?</TD></TR></TABLE><p>The car had already been driven a couple of hundred miles from a different dealer, but yes, I just drove it.
I would remove pads (an easy task)... flat sand them, then bed them properly.......
Re: Is it normal for brakes to squeak a bit (steamboatsig)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>steamboatsig</b> »</i></TD></TR><TR><TD CLASS="quote">I had to wine and dine my pads before I was able to "bed" them.</TD></TR></TABLE><p>I bet they still squeak! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
Re: Is it normal for brakes to squeak a bit (C130)
yes, but to paraphrase Freud, sometimes a squeak is just a squeak
It's not abnormal, but it sure is annoying. There is a Tech Note fix for the squeal that entails different pads and metal backing plates which, probably, change the resonance pattern of the braking system, and thus stop the squeal. I had it done to mine, and the difference in enjoyment of the car for such a seemingly simple annoyance cannot be overstated.<p>Do a search in the forum/archive and you can find the Tech Note / TNN.
Re: Is it normal for brakes to squeak a bit (mgotts)
<A HREF="http://www.alldata.com/tsb/Volvo/1112169600000_1118818800000_TNN51-09" TARGET="_blank">http://www.alldata.com/tsb/Vol...51-09</A>/
Re: Is it normal for brakes to squeak a bit (frankhoffy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>frankhoffy</b> »</i></TD></TR><TR><TD CLASS="quote"><A HREF="http://www.alldata.com/tsb/Volvo/1112169600000_1118818800000_TNN51-09" TARGET="_blank">http://www.alldata.com/tsb/Vol...51-09</A>/</TD></TR></TABLE><p>Unfortunately, that's for '04's and '05's only. I'm not sure that there is a fix for '06's.<p>
1 - 10 of 10 Posts
