Hi, I'm little confused.<p> Got the car back from body shop where it was sitting for a week, and now every time I press the brake pedal the (!) light comes up. The brake is weak, I've added some fluid last night but in doesn't help. I knew the brakes were not in a best shape a week ago, but I never had the light. I've checked the pads and they still have some meat left. <p> <IMG SRC="http://images6.theimagehosting.com/albums/5912/IMG_0770.JPG" BORDER="0"> <p> <IMG SRC="http://images6.theimagehosting.com/albums/5912/IMG_0774.JPG" BORDER="0"> <br> <br>Front rotors were machined about 50K miles ago as I bought these used from someone else here as an 302mm upgrade, and I have probably 45kmiles on the pads. Rears rotors are probably original, at least I haven't replaced these in last 3 years.<p>Did I just wear them out completely? I just never seen this symptom.. I mean the light...<p>Thanks.<p>
Re: Is it a time for a brake job? (Papa_Kirlo)
A break job wouldn't hurt at this point; however I would bleed all four wheels to be sure the fluid is making its way to all of the calipers.<p>I've had a tow-truck driver put a hook (only for tie-down, not hoisting) on the rear A-arm and pinched closed my driver's rear brake line. (I was not there when the car was being towed to the shop for a new engine.)<p>Suffice to say, if they had the car in a shop...any number of accidents could have happened. So check that you're getting fluid to and from all four calipers firs. The problem you descirbe could be many things.<p>Cheers,<br>Prospero
Re: Is it a time for a brake job? (Prospero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Prospero</b> »</i></TD></TR><TR><TD CLASS="quote"><br>Suffice to say, if they had the car in a shop...any number of accidents could have happened. <br>Cheers,<br>Prospero</TD></TR></TABLE><p>Thanks Prospero. you don't even know how close is your word. They managed to destroy one of my tires, side cut trough the cord. I noticed it only at home. <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0"> Had to switch to crappy summer tires last night because of that... I'm going try to complain, not sure how it will work out.. <p>Thanks, I'll try to bleed it first..<p>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Prospero</b> »</i></TD></TR><TR><TD CLASS="quote">A<B> break</B> job wouldn't hurt at this point; however I would bleed all four wheels to be sure the fluid is making its way to all of the calipers.<p></TD></TR></TABLE><br>You do mean a BRAKE job, correct? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
Re: Is it a time for a brake job? (Mk1Racer)
Cool, thanks everyone. Don't want to open can of worms, but... does ceramic pads work well with "Power Slot" rotors? Do they squeak?
Re: Is it a time for a brake job? (JRL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JRL</b> »</i></TD></TR><TR><TD CLASS="quote">You do mean a BRAKE job, correct? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> </TD></TR></TABLE><p>Actually it was sort of a pun and a play on words while I was at it. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0"> <p>One thing for sure...can't let much get past you, can I? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> <p>Cheers,<br>Prospero
