1 - 8 of 8 Posts
You'll need bigger spacers than 25mm, there is no way 9.5" can fit without a lower offset. Especially up front, I'd go as far as saying that 9.5" will not work.
Gabe had 17x8.5 et27 in the front, 17x9.5 et19 in the rear with 215/45/17 on all 4 corners on his 850.
In comparison to Gabes rear setup, running 17x9.5 et31 would be 12mm further in, which would result in horrible rubbing against the struts.
Ian has 18x8.5 and 18x10.5 on his 850, but I can't find any info on his offsets and tire sizes.
http://volvospeed.com/vs_forum/topic/154374-volvo-850-on-speedline-alessios/
Now the x70s wheel wells are a bit wider, but only a few MM. Use willtheyfit.com to test out wheel/tire combos
Also, what are you running for suspension?
are these the saw blades you had on the S60???? I can't see them fitting a V70, both physically and aesthetically.
I keep seeing your sawblades and adapters on craigslist here... :) lol
1 - 8 of 8 Posts
