Anyone know when upgrades are avaliable for MY02 V70 T5? Looking for their ECU upgrade packages. Also, once the boost psi is upgraded through the tuned ECU, is there like a stock bypass valve in the car or something to protect compressor surge? Because the car is quiet as hell, and engine bay is soooo clean, can't even see shi*t in there. If there is a bypass valve, would it be able to hold the upgraded psi, meaning would it leak under acceleration? According to the info on their website, after the upgrade, the turbo would produce 18psi from stock 10psi, that's a LOT of boost.....
