I read all these wonderful things about ipd sway bars....my question is does my v-70 asr already have sway bars? If I decided to go w/ the ipd product will the dealer install these items?
Re: ipd sway bars (ee778a)
Quote, originally posted by ee778a »
Yes, just not as thick as the ones IPD is selling.
Depends on your dealer. Mine would, but there are reports of dealers who won't install aftermarket parts.
Find a good indy mechanic...will be much cheaper than the dealer anyway. Or...do it yourself if you have the skills, tools and confidence. IPD sends installation instructions and all necessary part (bolts, and even special grease) with their swaybars. It is a bear to install though on the P2's.
Re: (MadeInJapan)
I'm looking at having the rear sway bar installed right now, be advised that it may require an SUM recalibration
see: http://forums.swedespeed.com/zerothread?id=55454
apparently a recal is required if they disconnect (electrically) the shock, which some shops may do in order to install the bar...though per the thread above this may not be 100% necessary. If you go to an independent shop, I'd make sure they either don't disconnect it or have the ability to do the SUM recal.
