1 - 6 of 6 Posts
Once again I need some advice. Is it worth it to add a strut tower brace (IPD has it on sale for $159) if you do not plan on modifing the suspension or wheel/tire size? Will I still feel a benefit (ie. better handling) or is it a waste of money? Thanks again for any input.
Thanks for the vote of confidence. I was hoping that would be the answer. IPD also claims that no wheel realignment is necessary. Was that your exeprience as well?
Thanks again.
Am using the IPD brace in combination w/their sway bar, and then added a new set of Bridgestone Potenza S-03s, 205/55/15 as mounted to new 15X7 wheels on a 42mm offset as compared to the OE 44mm--close enough/ a standard max. difference recommended of 5mm.
1 - 6 of 6 Posts
