1 - 13 of 13 Posts
1998 V70 T5 with factory m56h; 18t, Green injectors, 50% e85
Is it year-specific? Will it work on a '97 T5?
I am also interested in this ECU, and I have a '97 T5, how long have you had it? Are all the pins still straight? Thanks
Re: (pelicanflyt)
Not sure if it'll work on 97 T5.
If anyone on the post can answer question, please help.
ECU is stage 1 setup purchased in April from Swedespeed member Yellow95.
No bent pins and in excellent condition. Boost set to 14.7 lbs of pressure. Nothing wrong with ECU....I'm moving up to Stage 3 and will no longer need this one.
The '95 has EGR and the 97 does not. So it will throw a code for the missing EGR inputs.
Re: (Big Will)
Thanks Will.
No problem!
1 - 13 of 13 Posts
