Here's a dynamic Idea.....Resonator delete......doesn't matter what you have for a catback it WILL make your car sound beastly.Anyone ever have any problems with rain squeal with either the iPD or EST cat back exhausts?
The resonator looks smaller, but figured before I pull the trigger on one, better make sure it isn't a problem.
Thanks!
Not what he's asking. He probably doesn't want to pay a shop $75 to cut out a resonator after dropping $750 on a cat back. Let someone with an EST or IPD exhaust answer.Here's a dynamic Idea.....Resonator delete......doesn't matter what you have for a catback it WILL make your car sound beastly.
Out of your curiosity, what are you basing your opinion on? What's wrong with the EST unit vs IPD?I would go with the IPD unit. I have the est and the way the rear muffler looks on it bothers me. I also have the stright pipe and have never had rain squeal. If I were to do it all over again I would get the IPD system if that helps you.
You do not nave to cut EST system. And you can buy the one without the resonator:Thanks for the info so far!
I was leaning towards the EST because they are local for me, but the IPD is very appealing too.
While I did the resonator delete - I'd like to avoid chopping up a brand new cat back exhaust...
Nothing like a great sounding car that squeals in the rain - mind you, my brakes still scream bloody murder at lights!!
Thanks missed that one on the site.You do not nave to cut EST system. And you can buy the one without the resonator:
http://www.eurosporttuning.ca/mm5/m...Code=VLE-365-107&Category_Code=VL-S60-exhaust
No problems with the IDP unit. At first I modded the rain squeal mount to fit the oval section but after a DP swap the system was solid with plenty of clearance related to the drive shaft and the rain-squeal mount became overkill.Anyone ever have any problems with rain squeal with either the iPD or EST cat back exhausts?
Thanks!
Nuthing is really wrong with it as I stated. If I did it again I would go IPD because of the single 3 inch oval tubing and the way the system looks and sounds.Out of your curiosity, what are you basing your opinion on? What's wrong with the EST unit vs IPD?
I have slash cut tips from est. They look better in my opinnion then the stright round ones.Thanks missed that one on the site.
Just wish they didn't go with the round tips, like the old style
Just saw that, EST sport exhaust with down pipe $1326 delivered to California!!! Anyone know how long there sale is on for?? Don't promo code estsw4r3 for additional 10% off exhaust..EST sale, I can get the sport exhaust AND the DP for only a couple hundred more than the Elevate (and about the same as the iPD exhaust)!!
Now, can I convince the wife I need the RICA tune as well!
anyone have any issues with CEL's and the EST DP?
