1 - 8 of 8 Posts
Hey guys in have an ipd heavy duty turbo control valve for Volvo 01-09 s60, 01-07 v70, 01-07 xc70. It's only 2 months old and works perfectly, absolutely nothing wrong with it, only had it in my car for a couple weeks. I'm selling because soon after I bought it i got a tune for my s60 that required the use of the stock tcv so I no longer need this one. It's the 2nd generation valve which has improvements over the original. Comes with installation instructions and hose clamps for the vacuum lines that connect to it. $70oboPM or rely on post if you're interested. Thanks!
Info off ipdusa.com: IPD's second generation TCV provides stable boost control at levels that exceed the capabilities of the stock unit. Slow spool time and fading boost pressure is common with weak factory solenoids and can rob you of power you didn't know you lost. Our testing has shown that the factory valve is incapable of maintainin cycles at pressures above 16-17 psi of boost. This means your TCV can cost you boost at wide open throttle. While most applications will not boost this high, it demonstrates the reason that failure is so frequent on the original equipment.
IPD's heavy duty TCV is designed to handle high heat, high pressure, and tough environments and was built to last! The second generation valve maintains stable repeatability at speeds and boost levels unequaled by any other controller on the market. This is direct fit unity and typically installs in under ten minutes with no modification s or tuning required.
1 - 8 of 8 Posts
