1 - 13 of 13 Posts
my s60r sagged on one side (driver side) and I could not find anything wrong with suspension so I gave Ipd's rear spring adjusters a try...it helped...Thanks Ipd. :thumbup:
Did you install these on just one side? I just bought these for the same reason that you did, uneven on one side. If I only install on the drivers side, would that screw up the handling, due to uneven spring rates?
1. Did you install these on just one side?
2. If I only install on the drivers side, would that screw up the handling, due to uneven spring rates?
1. yes
2. no
the most you'll gain 1/4 of an inch in height.
Moderator
wait Dougy...so now you're RAISING your caR?
...I think you should have gone the other way and figured out how to LOWER the remaining corners :)
Discussion Starter · #5 · (Edited)
lol :beer: ... i wish i could figure out why these cows sags on driver side "LR" instead. :D
For all the custom fabrication, hard work and good effort you put into your SR, you still have the Autohaus plate surround? You have amusing priorities.
Interesting, I noticed that my SR sags on the driver side as well...
Thanks dougy, I'll probably do this when I do my spring seats.
Thanks Dougy!
my wife's R is lower on the drivers side but in the front only. Its about 1/4" lower than front passenger side. Same fix?
Sent from my SGH-T999 using Tapatalk 2
Thanks Dougy!
sure J.
no, this is for rear only...maybe your upper strut spring seat is busted? really 1/4 is not bad at all...if all is well, i'd leave it alone.
Yeah, swapped out strut for another one I had at the shop. Car got smoother. Weird thing is the spring is more compressed on that side, like there is 100lbs sitting on it. Oh well.
1 - 13 of 13 Posts
