Of course!...at nearly 100 mph. LOL
So new list of parts ordered.
Rear wheel bearing x2
Rear rotor and pads x2
Front lower control arm x2
Front sway bar end link x2
Passenger front wheel bearing
Inner tie rod x2
Outer rod x2
Trunk shocks (one is broken) x2
Cabin air filter
I think this will conclude a full stage 0 and some.
I just did that one.If you’re there you may as well do drivers side bearing. I’d add to the order. No sense in brushing half your teeth.
Have you done the math, yet? I’d be curious how closely your project has mirrored the adage that all R’s are at least $10k vehicles, either up front or after throwing parts at that deferred maintenance.Then my wallet can take a rest.![]()
I have. around $4800 in parts so far. I am trying to source some 18" Pegs and a full exhaust. Still need PDR and front and rear bumpers resprayed (and winglets). So all in I think I'll be around $12k on this R.Have you done the math, yet? I’d be curious how closely your project has mirrored the adage that all R’s are at least $10k vehicles, either up front or after throwing parts at that deferred maintenance.
I did all the labor...I can't even imagine. I have the remaining parts to go on, then alignment and PDR. Still trying to find someone to respray my bumpers and side skirts for a decent price. I plan on taking them off the car if it will make it cheaper. Car is great, pulls strong, sounds healthy. I might have to reinvestigate the hot start issue. I'll connect it to VIDA and monitor my fuel pump. It only does it on hot start and only at start up.Inflation...
You also did a lot of the labor, so I imagine it would have been a LOT more.
Thank you sir!!!!It does include all year Rs. Go for newer wagons as they'll be inside by the spare.
Almost any P2 I think, and P1s that are facelift. I got mine from inside an s40 under the rear seat and on driver side.
THAT is the picture of the PEM. Not VIN related so that's why they're easily interchangeable.
Thank you. I am starting to agree with you. I was under the car last night. No leaks. Everything looks clean. 4C refresh next spring along with some subframe bushings. I do need this car to start its daily driver dutyYeah - looks like those wheel bearings met a BFH!
Seriously, this is a new car. There's no way you'd find a car this fun and nice on a lot or anywhere else for the calculated cost (even including what you've spent on parts and your figured labor). NEVER.
I forget where you are, but you've got a little more than two weeks to clear your calendar for a long drive to Carlisle. It would be so nice to see this in person and meet you.
Might not be able to make Carlisle.
You are totally correct. If she is running by then I’ll make the trip. Would love to get some faces to these screen names.
It's a gathering of more Volvos that you could imagine.
It's also more about the camaraderie and seeing each other in person and sharing a beverage and some eats than showing off the ride.
