Hi,<br>My daughter's 82 245 Turbo wagon has started dropping out of overdrive intermittently when she's driving. <p>She says it goes in reliably, but sometimes just drops out for no apparent reason. <p>Any suggestions would be most appreciated.<p>Thanks,<p>Bob S. <br>Davis, CA
Re: Intermittent Overdrive on 245 Turbo (rwsams)
This is the manual transmission with the little slide switch on the gear knob right?<p>If so I would look at the OD relay first.<br>IIRC it's located to the left of the glove compartment or near the driver's right knee bolster.<br>
Thanks for the ideas. <p>It is the manual with the pushbutton switch on the gear nob. <p>Bob Sams
Re: (rwsams)
<A HREF="http://www.ipdusa.com/ProductsCat.aspx?CategoryID=131&NodeID=1236&RootID=629" TARGET="_blank">http://www.ipdusa.com/Products...D=629</A><p>
Here is an other suggestion. Check the two wires that go into the back side of the OD solenoid. Some times they brake due to heat. That is a cheap fix. The push button switch and the slide switch go bad too and can cause that issue. There is a mod you can do to relocate the switch to the centre console.<br>
i hope she has been using the clutch to go in and out of it. i dont think many people know that you have to do that to prevent damage.
