1 - 13 of 13 Posts
Has anyone replaced their interior lights with LEDs?<p>If so, where did you get them from
Re: Interior LEDs (Bender)
You could just get them on ebay. Other sites do have led but the charge more. If you buy from the right seller then the quality is usually better. besthongkong I think is the guys name on ebay i've used. Quick shipping and good products. But if you don't wire them correctly they will burn out prematurely so make sure you wire them right. Or you could try different approaches then the 3mm or 5mm leds in different locations.
my goal is to get high quality ones with the right resistors already built in, i dont mind spending a bit of money to do it.
Re: (Bender)
well <A HREF="http://www.ledsupply.com/ " TARGET="_blank">http://www.ledsupply.com/ </A> is a good site. Widely used on led forum I know. They don't have resistors built in. I've never bought any 3mm or 5mm that have built in resistors. You may be able to find some but I havnt before. <A HREF="http://www.eled.com/" TARGET="_blank">http://www.eled.com/</A> could look here as well. You're not wiring them in series so you could use this (<A HREF="http://www.quickar.com/noqbestledcalc.htm" TARGET="_blank">http://www.quickar.com/noqbestledcalc.htm</A>) to find what resistor you need. Look at the specs of whatever led you want and plug it into the calc.
Which lights are you talking about?<p>Footwell and dome, I assume?<p>Not dash, radio, buttons, switches...
Re: (StarmanDXE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>StarmanDXE</b> »</i></TD></TR><TR><TD CLASS="quote">Which lights are you talking about?<p>Footwell and dome, I assume?<p>Not dash, radio, buttons, switches...</TD></TR></TABLE><p>dome lights stay dimly lit in my 03...
Re: (StarmanDXE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>StarmanDXE</b> »</i></TD></TR><TR><TD CLASS="quote">Which lights are you talking about?<p>Footwell and dome, I assume?<p>Not dash, radio, buttons, switches...</TD></TR></TABLE><br>Correct
Re: (Bender)
You want a downlight? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
$100 = all inteiror lights .<p>Autolumination.com <p>send largest festoon bulb <p>/thread <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
Bender, i did this mod..the thread is somewhere in this forum(a lot time ago), include pictures, etc....i did also the cluster and panel leds too.
1 - 13 of 13 Posts
