Hi guys, I have a 01 V70 2.4T and the interior fan only works on LOW... As far as I can tell my Climate Control is fine as the all the lights are on, not blinking, all positions work and temps work. I was thinking a blower resistor but was looking for more insite before I start changing parts.
Thanks guys!
Either or...
Change both
I'm afraid of the $1000 price tag of a new CCM... I can't use a used one correct? That's why I was thinking of changing the resistor as the fan works on low. Every once and a great while after hitting a bump the fan will come to life. But as soon as I hit another good bump it goes back out.
Not the CCM, the blower motor and/or power stage (aka "resistor).
The consensus in my shop is blower motor/power stage go in as a package. If not, it usually comes back with the same problem and then it gets the other anyway.
You can find a decent aftermarket blower motor for about $100-$125 if you do some searching
The CCM is probably fine
You can also buy a lower mileage used motor and resistor
I believe they're all the same, 01-07, so call Erie and see what they have in stock this week
www.erievovo.com
1 888 volvo 13
