Deep Gloss Auto Salon
Mercedes Benz SLK 280
This vehicle was brought in for paint correction/protection, engine detail, interior detail and paintless dent repair.
First item on the list was wheels.
  • Autoglym CWC on rims and rubber
  • Optimum Power Clean on arches
  • Various brushes
Before:
During:
After:
Brushes used:
Attention was then focused on the engine
Optimum Power Clean and various brushes:
Before:
- I thought this was curious, a halls wrapper in the hinge area… -
During:
After initial dressing application:
Final after:
Door jambs were then cleansed:
Then paint was cleansed:
Left over wax was in many crevices, cracks and seams:
Initial foaming:
After dwell time:
2 bucket wash was then performed, and blown and blotted dry.
Exterior was clayed with Riccardo yellow and ONR lube.
Below you will see some random pictures depicting the overall condition of the vehicles paintwork.
Notice how all clarity is gone from what should (and will) be a deep black gloss!
Paint Correction Process:
  • Tuffbuff wool pad - M105 - Rotary
  • Tangerine Hydro M205 – Megs V2
  • Crimson Hydro 85rd – megs V2
  • Multiple IPA wipedowns
Yes, everything gets corrected (door jambs included):
Discussion Starter · #2 ·
Now time for some before and after shots… Lighting was dual halogens and 240 lumen Fenix tactical light – All afters in this “before and after” area are before final burnishing
Before (very deep defects):
After:
Before (again, very deep defects):
After:
Before – Notice the very deep abrasions from what appears to be an area of repeated abuse from the gas pump tubing:
A closer look:
After:
Before:
After:
Before:
After:
Before:
After:
Before:
After:
Before:
After:
The interior of the front emblem was far from proud as it was designed to be. That was rectified with a chemical cleanser/sealant Duragloss 501.
Below is a cropped half and half and then full view of full after.
50/50:
After:
Random halogen after shots:
After all correction was cpompleted, the vehicle was once again foamed and washed to remove any traces of oil or dust to ensure a clean surface was present for the sealant to cure properly for maximum durability.
Below are some direct sun shots after the wash but before any protection.
I include direct sun shots whenever the sun is available because any artificial light source can be manipulated to make it appear as though correction was achieved and this is not so with direct sun shots.
Sun Verification:
Below are some random shots before any protection… just shows that it’s all in the prep.
  • Hides: Leather master trio
  • Trim: 303
  • Seals: Gummi Pfledge
  • Carpets: 303 cleaner
  • Glass: Clearly Better
  • Exhaust Tips: CG Metal
  • Tires: Surf City Beyond Black
  • Rims: Rejex
  • Arches: CG Bare Bones
  • Brightwork: Duragloss 501
  • Exterior Glass: Rejex
  • Pedals: Power Clean
Below is a quick interior shot:
Below are some final beauty shots after all work was completed:
  • LSP : Menzerna Powerlock ( 2 coats)
  • Final wipedown: Duragloss Aqua Wax
Thanks for looking….
