1 - 15 of 15 Posts
my ipd iPod adpater is set to arrive next thursday, and I want to get the details out of the way first because I know I am going to install it as soon as it shows up.<p>I (think) I remember reading somewhere that you need to disconnect your battery before pulling the radio out otherwise you will get a SRS code?<br>Do I need a radio code once I plug everything back in? And if so where will I find this code because I sure haven't seen anything in the atacama case.<p>
Re: installing iPod adapter into S60 platform (phuz)
This may help: <A HREF="http://vccs.volvocars.se/accessories/ii/details.asp?DocId=111" TARGET="_blank">http://vccs.volvocars.se/acces...d=111</A><p>Although it's the iPod adapter from Volvo, it will tell you what to do and how.<p><br>And here's another: <A HREF="http://forums.swedespeed.com/zerothread?id=61802" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=61802</A><p>
thats the one...can't believe i didn't see it.<br>thanks man!
Re: (phuz)
Let me know if you have any other questions.... I tried to put most of the FAQ's in the above referenced post.... I think I have an extra power adapter, if you want to use it....
Re: (dugums)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>dugums</b> »</i></TD></TR><TR><TD CLASS="quote">Let me know if you have any other questions.... I tried to put most of the FAQ's in the above referenced post.... I think I have an extra power adapter, if you want to use it....</TD></TR></TABLE><p>doesn't the adapter get its power from the radio?
Re: (phuz)
Yes, you can certainly connect to power by splicing into the radio wiring(or anywhere else for that matter)...<p>The adapter I have makes it just so you don't have to splice into any of the car wiring... Just a convenience thing... I figured I'd offer it to you, since I had an extra... But certainly not REQUIRED by any means....
Re: (dugums)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>dugums</b> »</i></TD></TR><TR><TD CLASS="quote">Yes, you can certainly connect to power by splicing into the radio wiring(or anywhere else for that matter)...<p>The adapter I have makes it just so you don't have to splice into any of the car wiring... Just a convenience thing... I figured I'd offer it to you, since I had an extra... But certainly not REQUIRED by any means....</TD></TR></TABLE><p>how much $ u want for it?
Re: (dugums)
you are the man!<p>does this just plug into the 12v cig. lighter?
Re: (phuz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>phuz</b> »</i></TD></TR><TR><TD CLASS="quote">you are the man!<p>does this just plug into the 12v cig. lighter?</TD></TR></TABLE><p>It plugs into the back of the radio and then the wiring from the car plugs into the harness...
Re: (dugums)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>dugums</b> »</i></TD></TR><TR><TD CLASS="quote">I'll get it out Tuesday morning... Enjoy!!!<p>Let me know if you need anything else!!!</TD></TR></TABLE><p><br>man...this is so much appreciated.<br>THANKS!
Discussion Starter · #13 ·
w00t! iPod adapter was here when i got home from work. unfortunately i have other stuff to do tonight, so i will begin installation tomorrow. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"><p>for some reason i just watched the install DVD anyway. seems pretty simple.
Discussion Starter · #15 ·
Re: (dugums)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>dugums</b> »</i></TD></TR><TR><TD CLASS="quote">Did you get the harness yet???</TD></TR></TABLE><p>i will check when i get home. im leaving work soon cause its friday and i just plain don't have a lot going on <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
1 - 15 of 15 Posts
