1 - 2 of 2 Posts
HeY gents. I'm sure this has been discussed here a thousand times. I searched the site and googled but did not find the answers. Basically looking to install elevate springs, sways,adj. toe links, Rear camber bushing kit. Kindly post up what essential parts that needs to be replaced while I'm in there. Part numbers helps too. TIA..
Strut mounts and spring seats since you have to remove those to replace the springs. Struts if they show any signs of failing. Sway bar links. Control arm bushings if they're worn. Ball Joints. Essentially the whole suspension is suspect as these cars are not known for long life suspension parts..
1 - 2 of 2 Posts
