1 - 17 of 17 Posts
Wife is hard on brakes. Does anyone know what needs to be swapped to put the 305mm front rotors on, instead of the 286mm ones? Pads apear to be the same for either size, so I'm assuming(I know...)just the adapter?? Will the 305s fit with 16in wheels? Thanks guys
Re: Installing bigger front rotors? (BellevilleV70)
This appears to be the wrong forum, sir.
I know what forum it is, I can read. Regular forum doesn't get much traffic, nor does anyone seem to mod anything there. Thanks for the help.
Re: (BellevilleV70)
You're probably better off putting a beefier pad on there, and some better fluid, to handle the extra heat. The rotor itself is likely just fine. Take the backing plate/dust cover thing off to help dissipate heat as well.
Ive tried all kinds of pads, still not happy with it. Don't really want to pull the back plate due to all snow/salt up here, they rust fast enough now. Was going to try the centric EP coated rotors this time with akebono euro pads and see how they work. <p>That said I ordered rebuilt calipers with adapters for the bigger rotors, so i'll see if they bolt on and fit the wheels I guess. Can always return them if they don't.
Re: (BellevilleV70)
or show ur wife how to apply brakes correctly <p>Total Cost : $0<p> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
Re: (s140s)
or show ur wife how to apply brakes correctly <br>Total Cost : $0<p> <p>um......yeah we have been down that road. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> she's a hard driver, that ain't gonna change. <p><br>I'm curious, what's the benefit of bigger rotors without bigger pads? Better dissipation of heat?<p><br>Yes and more swept area<p><br>--------------------------------------------------------------------------------<br>
Re: (BellevilleV70)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>BellevilleV70</b> »</i></TD></TR><TR><TD CLASS="quote">or show ur wife how to apply brakes correctly <br>Total Cost : $0<p> <p>um......yeah we have been down that road. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> she's a hard driver, that ain't gonna change. <p><br>I'm curious, what's the benefit of bigger rotors without bigger pads? Better dissipation of heat?<p><br>Yes and more swept area<p><br>--------------------------------------------------------------------------------<br></TD></TR></TABLE><p>Why don't you install the S60R front calipers, rotors and pads to improve braking?
Wheels are too small, and thats not in the budget. Gonna be time for a new one in the next year or so.
post in Volvospeed.com. A lot fo techs there that might have info also.
Re: Installing bigger front rotors? (PMPN8EZ)
How about next time you start off with, "We don't have an R, but I was wondering about using blah blah blah blah on a standard v70..."? Maybe curtail a "wrong forum" comment. <p>And you seem to already have a plan in place, why ask for advice? <p>Lastly, the advice to tell your wife to knock it off is the best so far. Or just have the next few brake jobs come out of her pocket...<p>good luck whatever your course may be...cheers <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/embeer.gif" BORDER="0">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>BellevilleV70</b> »</i></TD></TR><TR><TD CLASS="quote">Wife is hard on brakes. Does anyone know what needs to be swapped to put the 305mm front rotors on, instead of the 286mm ones? Pads apear to be the same for either size, so I'm assuming(I know...)just the adapter?? Will the 305s fit with 16in wheels? Thanks guys </TD></TR></TABLE><p>I thought T5s had a bigger front brakes than 2.4Ts and would still work with 16" wheels? I maybe wrong, but that is where I would look first. S60 forum has people who mod, so you may get an answer there.
Discussion Starter · #14 ·
Re: Installing bigger front rotors? (T5 for Life)
How about next time you start off with, "We don't have an R, but I was wondering about using blah blah blah blah on a standard v70..."? Maybe curtail a "wrong forum" comment.<p><br>Thanks SO much for your help!!!<p> <br>And you seem to already have a plan in place, why ask for advice? <p><br>Because I was allready looking into it, and desided on ordering calipers after I couldnt find used adapter today. <p>Lastly, the advice to tell your wife to knock it off is the best so far. Or just have the next few brake jobs come out of her pocket...<p>She does pay for repairs not that that has ANYTHING to do with what I asked.
Discussion Starter · #15 ·
Re: Installing bigger front rotors? (I Roll)
I thought T5s had a bigger front brakes than 2.4Ts and would still work with 16" wheels? I maybe wrong, but that is where I would look first. S60 forum has people who mod, so you may get an answer there.<p><br>Thanks......thats what I ordered was T5 calipers......if they fit I'll go with the bigger rotors. <br>Thanks for the info folks. <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <br> <br>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>BellevilleV70</b> »</i></TD></TR><TR><TD CLASS="quote">I thought T5s had a bigger front brakes than 2.4Ts and would still work with 16" wheels? I maybe wrong, but that is where I would look first. S60 forum has people who mod, so you may get an answer there.<p><br>Thanks......thats what I ordered was T5 calipers......if they fit I'll go with the bigger rotors. <br>Thanks for the info folks. <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <br> <br></TD></TR></TABLE><p>Your posts will be a lot easier to read if you use the 'Quote' button to copy the previous post into yours instead of just copying and pasting.
1 - 17 of 17 Posts
