Well I finished the install of the VST strut brace yesterday and snapped of a few shots of some clearence issues with it. It only took about twenty minutes to do and anyone with a 14mm socket, 17mm wrench and 8mm allen wrench can do it.
The finish of the bar is pretty good, a couple of areas could have used a little more polishing.
Overall it looks really nice. Is it trully is functional? I don't know if we'll ever know.
Now for the part I was not happy with at all!!!
The left hand side of the brace does not clear the brake resevior filler cap and is pushing up against it pretty firmly. There is also a wire harness coveron the left side where the brace bracket pushes the cover back about 3/8". Not really that big of a deal, but for the money this thing should be flawless.
closer looks:
Well for $400 I figured this brace would have no issues at all, apparently it does on my 04 R. There is some adjument on the brace brackets and I have them maxed out, still the filler cap hits and the harness cover is pushed back. I'm really sure I have it installed correctly and you guys might see something I don't. Any other folks have these issues with thier install?
On the other hand the instructions make no mention of an install on the R model, only the AWD 01+ model was the closest to the R. It could be that IPD didn't know, but then again they have the same brace installed on thier V70 project car....
Kevin
Modified by KVB at 4:14 PM 2-11-2006
closer looks:
Kevin
