1 - 9 of 9 Posts
Discussion Starter #1
Installed the Eibach's and 10mm spacer,still rubbing a litlle?Why?<p>I have the stock 18 Pegs with 235/40 Pzero.But there is still rubbing,if I install 15mm spacer,maybe rub to the outer surface of the fenders?<br>
Re: Installed the Eibach's and 10mm spacer,still rubbing a litlle?Why? (xenophobic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>xenophobic</b> »</i></TD></TR><TR><TD CLASS="quote">Installed the Eibach's and 10mm spacer,still rubbing a litlle?Why?</TD></TR></TABLE><p>Because you lowered car an inch. 10mm spacers completely eliminate rub at stock height. Trust me, it would be MUCH worse without spacers. <p>15mm spacers DO NOT WORK on the front wheels, you will rub on outside fender everytime you hit a bump or dip.
Discussion Starter #3
Re: Installed the Eibach's and 10mm spacer,still rubbing a litlle?Why? ("R" Kelly)
do you hasve the same ruýbbing problems with the eibachs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>xenophobic</b> »</i></TD></TR><TR><TD CLASS="quote">do you hasve the same ruýbbing problems with the eibachs?</TD></TR></TABLE><p>I don't have Eibachs, I'm never going to lower the front of the car (rear will be lower 5/8" via TME springs in about a month). However, 3 others here did have Eibachs/Evolves and still reported SLIGHT rubbing, even with 10mm spacers. <p>Without the lowering springs, no rubbing with 10mm spacers.
Banned
Lowered, 5mm spacers, NO RUB whatsoever <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
Re: Installed the Eibach's and 10mm spacer,still rubbing a litlle?Why? (JRL)
I already lowered the car with Eibachs and I have some rubbing. I just got my 5mm spacers from Brice(Alamo/Svenske). Will see if that helps. <p>JRL....The TME springs don't drop the car as much as the Eibachs, are they also slightly less stiff? Remember, I bought those springs(Eibachs) from you....I'm just wondering.... Perhaps in the future I may swap them for the TME's....if it wasn't such an expensive proposition, especially after doing it once already...<p>Pete
Re: Installed the Eibach's and 10mm spacer,still rubbing a litlle?Why? (pafox)
Slight rub on the passenger side.<p>Eibach, 10mm spacers and Michelin PS2.
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>pafox</b> »</i></TD></TR><TR><TD CLASS="quote">I already lowered the car with Eibachs and I have some rubbing. I just got my 5mm spacers from Brice(Alamo/Svenske). Will see if that helps. <p>JRL....The TME springs don't drop the car as much as the Eibachs, are they also slightly less stiff? Remember, I bought those springs(Eibachs) from you....I'm just wondering.... Perhaps in the future I may swap them for the TME's....if it wasn't such an expensive proposition, especially after doing it once already...<p>Pete</TD></TR></TABLE><br>Probably, but I had a small rub STOCK with 17s now I have SOME lowering with the TME springs. However Now have 18s and a tire with a somewhat wider tread shoulder <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> Guess I'm lucky but also why I have said this set up is good
Eibachs here with aftermarket wheels +38mm offset, which effectively gives me an 8mm outward shift (equivalent to an 8mm spacer). Absolutely no rub on mine.
1 - 9 of 9 Posts
