1 - 17 of 17 Posts
I just drove my "R" home from "Zen" Volvo and the difference between the IPD rear and the <br>"Track" spec is night and day "Track" spec is really tight. it should be perfect for the road course hence "Track" spec. His anyone really driven there car hard or shall I say aggressive at the track. What are the most notable changes compared to the stock setup. <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <BR><BR>
<i>Modified by cloaked at 4:46 PM 8-18-2006</i>
Discussion Starter · #2 ·
Re: Installed IPD "Track" spec anti-sway bars (cloaked)
<IMG SRC="http://smileys.smileycentral.com/cat/10/10_3_6.gif" BORDER="0"><br>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>StaggRLee</b> »</i></TD></TR><TR><TD CLASS="quote"><p>Extrapolating the "track spec." setup from the "neutral handling" setup, I'd have to agree.<p>I recently did a track day with 22mm rear sway and TME springs. On sharp turns if you stabbed the brakes to the ABS threshold approaching a sharp turn-in for max. rear-to-front weight transfer, the handling was neutral. <p>If you wussed and backed off approaching the turn-in and didn't carry enough speed to brake hard for the turn in, it still understeered. I did this quite often. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/frown.gif" BORDER="0"> <p>Accelerating away from the apex it was very noticable as long as you released the front wheels and let it drift to the outside of the track.<p>The whole setup performed admirably but some driver skill and experience is definitely necessary to take full advantage of even the neutral setup.</TD></TR></TABLE> Thanks Stagg <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0">
Well, it does perform tons better than the stock setup for the track. There's a slight hint of initial oversteer when you corner hard into the turn, but physics take over thereafter and the car will still proceed to understeer. I'm running with -ve 1.5 front camber (I had to file the knuckles down a bit to get the figures) and that's still insufficient for 235 rubbers... 245 may be better but will rub pretty badly with my setup.
The track kit is one of the best mods I did on the S60R.
Ok i've been driving with my "R" with the new setup and it's working well it turns very flat now. I can't feel any body roll at street speeds even on a quick turn, very steady. I cant wait for the track event hehe<br><IMG SRC="http://smileys.smileycentral.com/cat/12/12_7_21.gif" BORDER="0">
i'm definitely ordering them soon and getting them installed iwth my springs.
Re: (Copeland)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Copeland</b> »</i></TD></TR><TR><TD CLASS="quote">How much was the install for the sways?</TD></TR></TABLE><br>255.00 small price for excellence <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> shaving off the seconds<p><BR><BR>
<i>Modified by cloaked at 8:28 PM 8-21-2006</i>
But, you could have done it yourself?<p>How hard is it?<p>also, did your supertone horns add any HP?
Re: (Copeland)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Copeland</b> »</i></TD></TR><TR><TD CLASS="quote">But, you could have done it yourself?<p>How hard is it?<p>also, did your supertone horns add any HP?</TD></TR></TABLE><br>No you can't do it yourself well, not the front anyway. <br>hehe no and neither did the "Track" spec anti-sway bars but don't tell anyone <BR><BR>
<i>Modified by cloaked at 8:29 PM 8-21-2006</i>
Re: (cloaked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>cloaked</b> »</i></TD></TR><TR><TD CLASS="quote"><br>255.00 small price for excellence <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> </TD></TR></TABLE><p>WOW! I've ordered my set and the local tuner quoted me $255 for the front and $170 for the rear!! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/mad.gif" BORDER="0"> Perhaps I should I shop around! <IMG NAME="icon" SRC="http://www.vortexmediagroup.com/images/banghead.gif" BORDER="0"> Think the dealer will do it? I hate alerting them to mods when I can avoid it . . .
Have done 40 track events in my 04 wagon.<br>Two or three days were stock suspension. Half the days had lower stiffer springs, then the next half had the track sways too, with the IPD HD endlinks installed shortly after the track sways. <br>Each incremental improvement was a noted difference on the track. Stopped tracking the car 'cause it is way too expensive to abuse this $40k car this way (al least $50k after all the mods), and I cannot adjust the camber to an appropriate angle.<br><IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/frown.gif" BORDER="0">
Re: Installed IPD "Track" spec anti-sway bars (SleepR)
what difference, IF ANY, would there be in body roll/handling between the IPD Track setup and EVOLVE's front/rear sway bar setup???
Re: Installed IPD "Track" spec anti-sway bars (23109VC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>23109VC</b> »</i></TD></TR><TR><TD CLASS="quote">what difference, IF ANY, would there be in body roll/handling between the IPD Track setup and EVOLVE's front/rear sway bar setup???</TD></TR></TABLE>im wondering the same; in the past though, when i asked people simply reccomended ipd's sways because that's their bread & butter -- theyve been doing it for years. plus, they're over $100 cheaper than the evolve sways.<p>i'm still deciding because i contacted alamo and htey have some evolve sways in stock and can give htem to me for about the same price as the ipd sways, so i gotta decide...
Re: Installed IPD "Track" spec anti-sway bars (Cicada)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Cicada</b> »</i></TD></TR><TR><TD CLASS="quote"><p>i'm still deciding because i contacted alamo and htey have some evolve sways in stock and can give htem to me for about the same price as the ipd sways, so i gotta decide...</TD></TR></TABLE><p>Based on no personal experience other than what I've read on this board, that's not even a decision worth thinking about.
1 - 17 of 17 Posts
