Re: Install of Boost Guage (fergs60r)
I installed a manual gauge in the cubby next to the radio. Here's my step by step (if I had known it before I started):
- Under dash to the fuse box you access with the driver door open.
- Pull out the foam stopper to the pillar in the fuse box.
- Pull out the rubber stopper in the pillar behind the door.
- Fish the line through (takes a little time, be careful of your paint when using a coat hanger.
- Remove the heat shield that hides the TCV. If you're standing in front of your car with the hood open, it's to the right of the airbox in front of the battery/fuse box. Use a 9mm socket to compress the restraints.
- From the engine bay, look into the body panel past the hood support. You'll be able to see daylight and hopefully your line. If you use the IPD blue silicone hose it will be easier to see if you have a black R like me. Fish the line through until you have all the slack through. You're not done, because the hood would close and pinch the line.
- Find the hole (about 3/8") directly accross from the TCV, thread your coat hanger in there toward the hydraulic hood support. For now, straighten the end of the hanger. Work it back until you get the end out right next to the support.
- Put a slight bend in the hanger and push the line onto it. Pull it slowly back and through the hole.
- Thread the line under/around the airbox to the tap point as identified here.
http://forums.swedespeed.com/zerothread?id=15323
Have fun.
