Necessary parts:
Lamp - Part number 30790449 from volvo $27.00 List price
Wire tap connectors - Available at any electronics or hardware store.
Receptacle housing - Part number 30682794 from volvo $7.09 List price
Repair Terminal - Part number 30656639 from volvo $1.35 List Price
Procedure:
You'll need to remove the door panel which is simple. There are two screws behind a cover in the grab handle area. Once they are removed, the whole panel just pulls off. It's held on with clips.
Once inside, you'll need to locate the wiring for the door lock switch. Using the wire tap connectors, use the two outer wires on the harness to hook up the LED lamp. It is pin 1 and 4 on the harness. The wire colors vary by year.
Then plug the lamp into the diffuser which is already in place in the door handle area. That's it. You're done!
Procedure:
