1 - 20 of 21 Posts
Re: Increase turbo PSI with secret button?? (caoz)
Its not talked about much but this little trick works wonders.
Re: Increase turbo PSI with secret button?? (850arrrsaylikepirate)
I have such button. So far it worked every time. With one push I was able move from T5 mode to R...
it's on my wallet though.
u need to press DSTC button 6 times
Re: (s140s)
So what happens to it in Advanced mode and you do this trick?
I did this ONCE, and I'll never do it again. No one got it on film, but there was a slight incline to the road and it looked something like this:
When I came down, I had 4C error codes all over the place. Be careful guys.
Re: (CM2RAS)
Happy 4th.
If you're really this gullible,
time to move on now.
There is nothing, no secret taps or buttons to push, you have what you have.
Re: (j0sie27)
Quote, originally posted by j0sie27 »
ok so i hit the dstc button 6 times...what message am i looking for? how do i know that my boost has increased? or am i missing the entire point of this thread?
I found a new secret code today.
An old swedish man told me this secret, he was one of the developers who created our S60's.
Here's the process....
Make sure your car is running.
Make sure windows are all the way up and all doors closed.
Turn temp on heater up all the way, and on auto.
Press DSTC button 33 times, 1 second apart between presses.
After 33rd press QUICKLY get out of the car and press the trunk release button. You only have 2 seconds to complete this step.
Climb in trunk, close trunk, then use emergency release to open trunk back up.
Do NOT close trunk, get back in car.
Close door.
Buckle/unbuckle seatbelt 8 times ending with it buckled.
This is the hardest part.....
Now you have to open the drivers door from the inside, then go around and open passenger door from outside.
If successfull DIM will display "Safety limiter disabled"
If unsuccessfull turn car off and try again.
Re: (firehawk618)
Quote, originally posted by firehawk618 »
Close door.
AKA Chinese fire drill. Which may be a new feature if Volvo gets gobbled up by China.
im retarted
Yep.
Re: (firehawk618)
Close door.
I'd really appreciate it if someone could post a youtube vid on this procedure to make sure I get it right. Thanks in advance! http://********************/smile/emthup.gif
1 - 20 of 21 Posts
